martinkitching
Sep 20, 2020Aspirant
RN214 vertical expansion failed
Hi all I foolishly managed to overlook the fact that my ReadyNAS214 (4x 2TB) was nearly full and I've switched one of the 2TB disks for a 4TB disk. Using Frontview I can see that I now have 1x 3...
Sandshark
Sep 20, 2020Sensei
It didn't fail, you didn't give it the space it needs. The added 2TB of the 4TB drive has nothing to use for redundancy, so it remains unused until it does, which can only be solved by swapping out yet another 2TB for a 4TB or larger. The, the volume will grow by 2TB -- 2TB of additional space and 2TB of additional redundancy. If it's larger, then anything above 4TB will be in the same situation and go unused until it has a "mate".
martinkitching
Sep 24, 2020Aspirant
Thank you :-) All makes sense now! Although, adding another 4TB disk hasn't panned out as expected so I'm about to start a new thread
- Sep 06, 2016Retired_Member
