EpicMorg's avatar
EpicMorg
RN21400 - is it possible to upgrage os inside via apt?
Hello everyone! I've got RN21400 model. And I have been using it for 2-3 years. All is working ok.
I connected via ssh and saw that I have old debian on board.
And I have  some questions:
  1. Can I replace "jessie" to "stretch" or "buster" in the sources.list?
  2. Will it be safe for data (i have jbod massive of 4 disks) in HDD if i upgrade os (apt upgrade)?
  3. Can future firmwares from web-panel broke something?
  • If you make that upgrade, you will have to replace everything and essentially have Netgear hardware running FreeNAS.
    Buster is still in the test phase.  I don't know why you wouild even consider putting that on your NAS.
    Stretch is the current release.  The changes are significant, and I'm happy to wait until Netgear has fully tested an OS version based on it before releasing.  But I'm sure they will, just as they did migrate to Jessie.
    Jessie is still in long term support, so security patches and the like are still being released.  If I were using Linux on a desktop system, there may be a compelling reason to jump to Stretch, but it's a NAS.
    • Hopchen's avatar
      Hopchen
      Prodigy
      I agree with Sandshark here. A NAS is supposed be reliable over everything else.
      Installing a cutting edge OS version on the box, makes no sense to me.
      NETGEAR will migrate to never versions of Debian when they see it necessary. The important components of the NAS are very much up-to-date, such as the filesystem (BTRFS) version, Anti-Virus, etc. It does not really matter then, what version of Debian it is running and better to run something tried and tested, for a NAS solution.
    • EpicMorg's avatar
      EpicMorg
      Thank you all very much for the answers. I was just curious, no more. I will not touch anything, and let everything be as it is.
ProSupport for Business
