tec-man's avatar
tec-man
Guide
Dec 07, 2015
RN102 will not upgrage firmware
I have a 102 running 6.2.5.  I had tried (multiple times and methods) to upgrade to 6.4 without luck.  After the reboot it is back to 6.2.5 with no errors in the log file.  I also tried installing the Netgear APP to deal with the checksum, but it would also not load.
Now I tried 6.4.1 with the same results.  My other Readynas units have upgraded w/o any issues.
Any ideas out there ?
Paul
  • tec-man's avatar
    tec-man
    Apr 26, 2016
    I got my PM from a Netgear Tech/Engineer.  After a few back and forths, he remoted into my ReadyNAS and was able to force an upgrade.
    Great support solving the problem.  Hopefully he will get a hold of you and do same.
    Paul
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi tec-man,
    Welcome to the community!
    Are you doing the automatic or manual Firmware update? Perhaps use a different computer or web browsers.
    Kind regards,
    BrianL
    NETGEAR Community Team
    • mdgm-ntgr's avatar
      mdgm-ntgr
      If that does not resolve it, have you checked the contents of initrd.log?
      Does it show that the update failed?
      • tec-man's avatar
        tec-man
        Guide
        I have tried both manual and auto updating.  Also the log shows rebooting and background task starting.  No errors of any type.
        paul
ProSupport for Business
