CMDIT
Sep 07, 2021Aspirant
RN3138 (fw 6.10.5) - became unresponsive after enabling sleep hard drive during inactivity feature
After enabling the "sleep hard drive during inactivity feature" the unit stopped responding, web page does not work, cannot ping IP addresses, Raidar does not detect it. The unit responds normally wi...
CMDIT
Yes, I am able to get into tech support mode, is there a way to disable that feature there? If not, how do I revert to a previous firmware?
Sep 07, 2021Guru - Experienced User
Likely there is, but I am not certain what it is. You might list /etc/hdparm.conf and see if it is in there.
I haven't needed to do this myself, but I believe you first copy the firmware .img file to /root and then do
echo /root/name_of_image_file > /etc/.flash_update
Then reboot the NAS (the reboot command should work).
