CMDIT
Sep 07, 2021Aspirant
RN3138 (fw 6.10.5) - became unresponsive after enabling sleep hard drive during inactivity feature
After enabling the "sleep hard drive during inactivity feature" the unit stopped responding, web page does not work, cannot ping IP addresses, Raidar does not detect it. The unit responds normally wi...
Sep 07, 2021Guru - Experienced User
CMDIT wrote:
Yes, I am able to get into tech support mode, is there a way to disable that feature there?
Likely there is, but I am not certain what it is. You might list /etc/hdparm.conf and see if it is in there.
CMDIT wrote:
If not, how do I revert to a previous firmware?
I haven't needed to do this myself, but I believe you first copy the firmware .img file to /root and then do
echo /root/name_of_image_file > /etc/.flash_update
Then reboot the NAS (the reboot command should work).
CMDIT
StephenB wrote:
CMDIT wrote:Yes, I am able to get into tech support mode, is there a way to disable that feature there?
That file does not exist. Any other ideas?
CMDIT wrote:If not, how do I revert to a previous firmware?
echo /root/name_of_image_file > /etc/.flash_updateThen reboot the NAS (the reboot command should work).
- StephenBSep 08, 2021Guru - Experienced User
CMDIT wrote:
You might list /etc/hdparm.conf and see if it is in there.That file does not exist. Any other ideas?
Odd, as it is on all my NAS. But looking at the ones with spindown enabled, it doesn't seem to be controlled from there. It looks like the NAS manages spindown with rnutil. But I'm not seeing where the spindown schedule is stored - it might be in the ReadyNAS database somewhere.
Did you enter
rnutil chroot
after you got into tech support mode? That will start RAID, and chroot in one step.
After that you can try mounting the NAS data volume, and see if that works.
btrfs device scan btrfs fi show mount /dev/md127 /data
Note the above assumes your volume is named data (as it would be if you are using XRAID).
CMDIT wrote: Any other ideas?
Use journalctl to look at the NAS error logs, and see if you can find the start up errors.
- SandsharkSep 08, 2021Sensei
It is my understanding that drive spin-down has been disabled on all rackmount units. I don't know when that happened. It stll shows up as an option on my legacy 12-bay units converted to OS6, but does not seem to actually do anything. Also, I'm still running 6.9.6 on them.
FWIW, even if spindown is working, it doesn't seem likely that it is actually the cause of your problem. Spindown wouldn't kick in until well after boot ( I think the default threshold is 5 minutes) - and your NAS isn't booting at all. So I am thinking that something else might be wrong.
That is one reason for looking in journalctl, and also one reason I suggested trying to mount the data volume in tech support mode.
It is also possible to test the disks with smartctl.
