ThiloS
Nov 18, 2019Aspirant
RN314 - Every morning: volume error read only.
Hi there, every morning while my backups are running the system says: on volume data an error appears - and puts it into read-only mode. I checked all HDDs and they show no ATA error. I did...
Nov 19, 2019Guru - Experienced User
Ok. Can you figure out if one backup job is triggering this problem? If the damage is limited to one share, then you could potentially re-create that share.
ThiloS
Nov 19, 2019Aspirant
If i reboot the nas i can easily finish every backup-job without a problem... : - (
So i can't see a problem with a specific backup-job
