JohnWill
Apr 24, 2022Tutor
RN314 - Stuck on boot following firmware update
Following a pop up prompt from the web interface of my RN314 I updated the firmware. It downloaded and prompted a reboot. I clicked to reboot but after sometime it hasn't come back online - not vis...
ChrisGlynne
Apr 26, 2022Initiate
I have the same issue... firmware update to latest edition appeared to go smoothly but power LED has stopped blinking but display is showing "Booting..." for the last 10 minutes. No access to web portal. Not sure what to do next.
- SandsharkApr 26, 2022Sensei
ChrisGlynne, there are a number of things that can cause this, and yours is likely not the same as the OP's. A new post instead of a "me too" here will allow us to help each of you without confusing the other.
- JohnWillApr 26, 2022TutorMine was stuck on booting with 4 dots. In the end I pushed the power button on the front, once off, once on. That time it showed ‘updating FW’ briefly, then proceeded to boot only showing percent progress as well. It stuck for some time at about 59%. I was about to give up then it completed and was working normally again.
- ChrisGlynneApr 26, 2022Initiate
After 3 hours I decided to adopt the same approach and powered off and back on... it went through a series of 'Updating FW" cycles and then came up with the progress % display which ultimately succeeded. All looks good now and no errors I could see. So maybe it just needed a power down refresh.
