JohnWill
Apr 24, 2022Tutor
RN314 - Stuck on boot following firmware update
Following a pop up prompt from the web interface of my RN314 I updated the firmware. It downloaded and prompted a reboot. I clicked to reboot but after sometime it hasn't come back online - not vis...
ChrisGlynne
Apr 26, 2022Initiate
I have the same issue... firmware update to latest edition appeared to go smoothly but power LED has stopped blinking but display is showing "Booting..." for the last 10 minutes. No access to web portal. Not sure what to do next.
Sandshark
Apr 26, 2022Sensei
ChrisGlynne, there are a number of things that can cause this, and yours is likely not the same as the OP's. A new post instead of a "me too" here will allow us to help each of you without confusing the other.
