curso
Dec 20, 2024Tutor
RN314 don't boot anymore after trying to fix "no space left on device" error.
Hi, Here's the full story that led me to a ReadyNAS RN314 that no longer starts with a "flush_space+5a" message on the LCD. Actually, after seeing that I lost (I mean visible on the network) th...
curso
Dec 21, 2024Tutor
Hi Stephen,
Thanks for your quick reaction.
I just logged in as root in Tech support mode.
Launched the rnutil chroot command but I got a "killed" message like you can see
I guess it failed with the message "flush_space+5a" on the LCD. I still tried the brtf command in case but it failed.
# btrfs fi usage //
ERROR: not a btrfs filesystem: //
Dec 21, 2024Guru - Experienced User
Does
rnutil start_raids
fail the same way?
- cursoDec 21, 2024Tutor
Here is output of the command, seems a bit better
3C34390V00C6B login: root Password: # rnutil start_raids mdadm: /dev/md/0 has been started with 4 drives. mdadm: /dev/md/1 has been started with 4 drives. mdadm: /dev/md/data-0 has been started with 4 drives. mount: mounting LABEL=7c6e9e38:data on /data failed: No such file or directory Scanned Btrfs device /dev/md/data-0 #the mount on /data failed and indeed, it is empty
You can find here https://drive.google.com/open?id=1--vOp-VNXZAUipZuPT-TFqgmk7ltMuwi&usp=drive_fs the dmesg outpout in case you can find some usefull information.
- StephenBDec 21, 2024Guru - Experienced User
Ok. Does mount | grep md0 show that the OS partition has been mounted?
If not, try mount /dev/md0 /sysroot
If it's mounted, you should then be able to check the usage.
The /dev/md0 was not mounted.
I tried to mount it and unfortunatly it failed.
# mount | grep md0 # mount rootfs on / type rootfs (rw,size=2011292k,nr_inodes=502823) proc on /proc type proc (rw,noatime,nodiratime) sysfs on /sys type sysfs (rw,noatime,nodiratime) udev on /dev type devtmpfs (rw,noatime,nodiratime,size=10240k,nr_inodes=502828,mode=755) devpts on /dev/pts type devpts (rw,noatime,nodiratime,mode=600,ptmxmode=000) # mount /dev/md0 /sysroot Killed
