curso
Dec 20, 2024Tutor
RN314 don't boot anymore after trying to fix "no space left on device" error.
Hi, Here's the full story that led me to a ReadyNAS RN314 that no longer starts with a "flush_space+5a" message on the LCD. Actually, after seeing that I lost (I mean visible on the network) th...
Dec 24, 2024Guru - Experienced User
curso wrote:
How I fix them to make the balancing working?
Check the usage again, looking specifically at unallocated space.. Despite the checksum, the balance did appear to work.
What does this return?: btrfs inspect-internal inode-resolve 278 //
Normally it will return the file name of the corrupted file.
curso
Dec 25, 2024Tutor
I ran it here is the result
root@readynas:/tmp# btrfs inspect-internal inode-resolve 278 //
ERROR: ino paths ioctl: No such file or directory
root@readynas:/tmp# ls -il /
total 48
256 drwxrwxr-x 1 root root 674 Dec 24 16:27 apps
257 drwxr-xr-x 1 root root 1738 Mar 16 2024 bin
374 drwxr-xr-x 1 root root 0 May 21 2012 boot
12249745 -rwxr-xr-x 1 root root 4160 Jun 4 2013 cp_check_md5sums.sh
256 drwxr-xr-x 1 root root 586 Dec 24 16:55 data
1025 drwxr-xr-x 16 root root 3380 Dec 24 16:01 dev
422 drwxr-xr-x 1 root root 3574 Nov 23 12:22 etc
194065248 drwxr-xr-x 1 root root 54 Mar 16 2024 frontview
89278 -rw-r--r-- 1 root root 0 Jun 18 2014 ftp_ban.tbl
256 drwxr-xr-x 1 admin admin 28 Mar 17 2018 home
9699 lrwxrwxrwx 1 root root 5 Jun 18 2014 homes -> /home
1320 drwxr-xr-x 1 root root 822 Mar 16 2024 lib
12093 drwxr-xr-x 1 root root 1304 Aug 15 2017 lib32
2197 drwxr-xr-x 1 root root 40 Mar 16 2024 lib64
2199 drwxr-xr-x 1 root root 0 Mar 23 2024 media
2200 drwxr-xr-x 1 root root 26 Jan 25 2016 mnt
2201 drwxr-xr-x 1 root root 98 Oct 11 2022 opt
193170984 drwxr-xr-x 1 root root 4 Aug 26 2023 path
1 dr-xr-xr-x 328 root root 0 Dec 24 16:00 proc
2351 drwx------ 1 root root 620 Dec 24 16:56 root
1235 drwxrwxr-x 28 root admin 1080 Dec 24 16:02 run
2355 drwxr-xr-x 1 root root 2944 Mar 16 2024 sbin
2510 drwxr-xr-x 1 root root 0 Feb 28 2012 selinux
2511 drwxr-xr-x 1 root root 0 Jun 4 2012 srv
1 dr-xr-xr-x 12 root root 0 Dec 24 16:40 sys
188474452 -rw------- 1 root root 18 Feb 21 2024 syslog
2513 drwxrwxrwt 1 root root 178 Dec 25 20:07 tmp
2514 drwxr-xr-x 1 root root 112 Oct 11 2022 usr
8070 drwxr-xr-x 1 root root 188 Mar 16 2024 var
181144103 drwxr-xr-x 1 root root 42 May 7 2022 yacht
root@readynas:/tmp#Then I do not no which file(s) is(are) corrupted.
But by curiosity I ran again btrfs balance // and this time it stopped with a "no space left on device" error message. I ran several times with the same error message, but when I run "", the allocated space was no more 4.0GB 8-), there is progress.
root@readynas:/tmp# btrfs fi df -H //
Data, single: total=2.59GB, used=2.23GB
System, DUP: total=33.55MB, used=16.38kB
Metadata, DUP: total=134.22MB, used=42.73MB
GlobalReserve, single: total=33.55MB, used=0.00B
root@readynas:/tmp# btrfs fi usage /
Overall:
Device size: 4.00GiB
Device allocated: 2.72GiB
Device unallocated: 1.27GiB
Device missing: 0.00B
Used: 2.16GiB
Free (estimated): 1.61GiB (min: 993.96MiB)
Data ratio: 1.00
Metadata ratio: 2.00
Global reserve: 32.00MiB (used: 0.00B)
Data,single: Size:2.41GiB, Used:2.08GiB
/dev/md0 2.41GiB
Metadata,DUP: Size:128.00MiB, Used:40.75MiB
/dev/md0 256.00MiB
System,DUP: Size:32.00MiB, Used:16.00KiB
/dev/md0 64.00MiB
Unallocated:
/dev/md0 1.27GiB
root@readynas:/tmp# ls -al /var/cores/core-readynasd
-rw------- 1 root root 281935872 Aug 16 2018 /var/cores/core-readynasd
root@readynas:/tmp# ls -alh /var/cores/core-readynasd
-rw------- 1 root root 269M Aug 16 2018 /var/cores/core-readynasd
root@readynas:/tmp#
- StephenBDec 25, 2024Guru - Experienced User
You now have some unallocated space so no need to run balance again.
curso wrote:
I ran it
No, you didn't. The command is
btrfs inspect-internal inode-resolve 278 //The two dashes (inspect-internal and inode-resolve) matter.
You can delete this file.
- cursoDec 25, 2024Tutor
OK
Thanks for your support and help.
I whish you a nice and happy end of year 2024.
