Amit_W
Feb 22, 2018Aspirant
RN314-Err Used Disks after firmware upgrade 6.6.0 to 6.7.1
Hello, I just ran an update of firmware on my NAS device from 6.6.0 to 6.7.1, with 4 drive bay on RAID 5 After the upgrade it requested a reboot , however on restart it is now giving an Error...
- Mar 01, 2018
Dear John,
I managed to get some assistance and copy away the data to external USB through the tech support boot menu option.
Have now gone back to factory default on the NAS and rebuilding the volumes.
Thank you.
Regards
Amit
JohnCM_S
Feb 22, 2018NETGEAR Employee Retired
Hi Amit_W,
Welcome to the community!
You may want to check the health of the disks first. You can use the disk manufacturer's disk diagnostic tools (SeaTools for SeaGate disks, WD Data LifeGuard Diagnostics for Western Digital disks).
Upon checking on our system, you have a lifetime chat support with NETGEAR. I suggest to contact NETGEAR Support so they can also further investigate the issue.
JohnCM_S
NETGEAR Community Team
Amit_W
Feb 23, 2018Aspirant
Hi Jihn,
Thanks, i check teh harddrives and they seem to be fine. Since the issue happened immediatly after an upgarde of teh firmware i suspect that this is related with the OS or corrupt firmware upgrade
Unfortuantl ythe online Chat support has been unvailable. I would format the harddrives and start again as suggested by RAIDar but i require the data and cannot afford to loose this
Regards
Amit
- JohnCM_SFeb 24, 2018NETGEAR Employee Retired
Hi Amit_W,
Th error that you are getting is probably would be caused by a full root volume.
If you are able to boot the NAS in Tech Support mode, it will be best to contact NETGEAR support ( https://www.netgear.com/support/contact.aspx) so they can access the NAS. If chat is unavailable, you may contact them via phone but you will be required to purchase a support contract before they can assist you.
JohnCM_S
NETGEAR Community Team- JohnCM_SFeb 27, 2018NETGEAR Employee Retired
Hi Amit_W,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,JohnCM_S
NETGEAR Community Team- Amit_WMar 01, 2018Aspirant
Dear John,
Thank you.
Regards
Amit
