teachermanret
Oct 25, 2017Aspirant
RN314 not updating firmware
Hi, I'm using an RN314 which has been working very well for the last 2 years. I checked yesterday by clicking the update tab in the admin section and instantly a popup said 'Cannot connect. Commu...
- Oct 26, 2017
teachermanret wrote:
Sorry can't get the second option via Airport Extreme capsule to work. Perhaps a little more detail please?
http://www.macinstruct.com/node/553
Could this be why the Admin Update doesn't work?
If you configured a static IP address in the NAS it is more likely that you did that incorrectly.
teachermanret
Oct 26, 2017Aspirant
Hello,
I looked at the system logs and late this last August 27 System shutting down 10:0pm, August 28, 9:01am ReadyNAs background service started, 9:17am Antivirus updated, 9:27am System rebooting, 9:30 Successfully migrated ReadyCloud proxy settings to global proxy settings (Whats that about), a second later System Alert message failed to send. And it's been like that ever since. Could this be why the Admin Update doesn't work?
Thanks
Pete Miles
Oct 26, 2017Guru - Experienced User
- teachermanretOct 27, 2017Aspirant
Ha!, cracked it. Isn't it easy when you know how!
So thanks for all your replies and suggestions.
Pete
