MrOrc
Oct 06, 2014Aspirant
RN31400 max capacity
Hi! WD RED 6 TB is on the hardware compatibility list, but according to specs the maximum capacity is 16 TB. If you install 3 X 6 TB with raid 5, how much actual space do you get, and what happens ...
Oct 06, 2014Guru - Experienced User
It should handle 4x6TB drives. In jbod, that would be 24 TB, in RAID-5, it would end up 18 TB.
