MrOrc
Oct 06, 2014Aspirant
RN31400 max capacity
Hi! WD RED 6 TB is on the hardware compatibility list, but according to specs the maximum capacity is 16 TB. If you install 3 X 6 TB with raid 5, how much actual space do you get, and what happens ...
Oct 06, 2014Guru - Experienced User
Yes, typed it wrong. I just edited it.
mdgm wrote: I think you mean 18TB in RAID-5.
Well, ~16 TiB really. But of course Microsoft and others insist on labeling it TB.
mdgm wrote: Of course disk manufacturers use 1TB = 1000^4 Bytes, whereas the NAS uses 1TB = 1024^4 Bytes. Different measurements, same amount of space. So the actual volume capacity will be a little over 16TB.
