Michael_Oz
Dec 22, 2019Luminary
RN316 - backup log "does not have detail log when volume is in read-only mode"
I just did a backup, it completed, but the log says Backup Start Time: Mon 2019 Dec 23 10:05:37
Backup Finish Time: Mon 2019 Dec 23 13:03:49
Backup Status: Success
-------- Backup Job Log -----...
Dec 23, 2019Guru - Experienced User
... Backup job does not have detail log when volume is in read-only mode.
New one for me. I am wondering if the OS volume might be in read-only mode. Did you try downloading the full log zip file?
Michael_Oz
Dec 23, 2019Luminary
Dec 23 10:05:32 RN316A fvbackup-q[5184]: write(/var/log/frontview/backup/status_backup_009,BACKUP_STATUS__IN_QUEUE!!1577055932!!OK) Dec 23 10:05:32 RN316A fvbackup-q[5184]: Push: job_id=9 q_wp=20 q_rp=20 Dec 23 10:05:37 RN316A fvbackup-q[5184]: cmd=/frontview/bin/fvbackup -e 9 Dec 23 10:05:37 RN316A fvbackup-q[5184]: fvbackup.c:1106 (error) mkdir(/apps/.backup/) failed. Dec 23 10:05:37 RN316A kernel: CIFS VFS: cifs_mount failed w/return code = -95 Dec 23 10:05:37 RN316A kernel: CIFS VFS: cifs_mount failed w/return code = -95 Dec 23 10:05:37 RN316A fvbackup-q[5184]: mount error(95): Operation not supported Dec 23 10:05:37 RN316A fvbackup-q[5184]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) Dec 23 10:05:37 RN316A kernel: CIFS VFS: cifs_mount failed w/return code = -95 Dec 23 10:05:38 RN316A kernel: CIFS VFS: cifs_mount failed w/return code = -95 Dec 23 10:05:38 RN316A kernel: CIFS VFS: cifs_mount failed w/return code = -95 Dec 23 10:05:38 RN316A fvbackup-q[5184]: mount error(95): Operation not supported Dec 23 10:05:38 RN316A fvbackup-q[5184]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) Dec 23 10:05:38 RN316A kernel: CIFS VFS: cifs_mount failed w/return code = -95 Dec 23 10:06:01 RN316A cron[6609]: (*system*frontview-backup) RELOAD (/etc/cron.d/frontview-backup) ... Dec 23 13:03:49 RN316A readynasd[16716]: Successfully completed backup job MePC D VMs.
Where does that live?
I'll try rebooting.
- StephenBDec 24, 2019Guru - Experienced User
Michael_Oz wrote:Dec 23 10:05:32 RN316A fvbackup-q[5184]: write(/var/log/frontview/backup/status_backup_009,BACKUP_STATUS__IN_QUEUE!!1577055932!!OK) Dec 23 10:05:32 RN316A fvbackup-q[5184]: Push: job_id=9 q_wp=20 q_rp=20 Dec 23 10:05:37 RN316A fvbackup-q[5184]: cmd=/frontview/bin/fvbackup -e 9 Dec 23 10:05:37 RN316A fvbackup-q[5184]: fvbackup.c:1106 (error) mkdir(/apps/.backup/) failed.
/apps is a mount point on the OS partition that normally mounts /data/.apps
Rebooting is a reaonsable idea.
- Michael_OzDec 24, 2019Luminary
After reboot
Backup Source: [remote:cifs]///192.168.1.22/D$/VM Backup/MeB3 20191125
Backup Destination: [backup]/VMs/VMware/MeB3 20191125
Backup Start Time: Tue 2019 Dec 24 18:19:11
Backup Finish Time: Tue 2019 Dec 24 21:13:06
-------- Backup Job Log --------
Copy File 564d0a26-748e-bda6-50a6-68cef2657bac.vmem
Copy Folder 564d0a26-748e-bda6-50a6-68cef2657bac.vmem.lck
Copy File 564d0a26-748e-bda6-50a6-68cef2657bac.vmem.lck/M29732.lck
Copy File MeB3 - Copy.vmx...
So cosmic-rays are to blame...
