nifter's avatar
nifter
RN316 - Rejoin drive to dead volume?
I've been using my RN316 (OS 6.10.7) for many years.
X-Raid with 4TB+4TB +4TB+6TB drives.
I got a new 10 TB drive I was going to use for backup. I had trouble with the RN detecting it via esata or in a usb dock so I plugged it into bay 6 of the nas to see if it would detect. It was in there for about 15 seconds, then I pulled it out.
The array said degraded, but I didn't see how those 15 seconds would have caused any significant changes.
I continued copying data from my RN to other targets using teracopy to verify all files without any issue.
When I started to run out of space, I did something stupid. I thought the raid should be able to continue with one drive failure, so I pulled the 6TB drive. It was only out for about 30 seconds before I saw the errors in the web console and LCD. I quickly reinserted the drive.
Now the data volume says "Volume is inactive or dead" but I can still access it. I see nearly everything. Some folders are empty and some return I/O error when I attempt to ls them in ssh.
The volumes page has a new "data-0" volume (14.54 TB) and "data-1" volume (1.82 TB) with the original data volume as inactive.
I know it's a long shot, but is there any linux/btrfs magic where I could rejoin that 6TB drive to the volume?
I'm linux savvy.
I have a log bundle.
  • StephenB's avatar
    Bad idea if you were running XRAID.  The NAS would have tried to automatically add the 10 TB drive to the array. Once the NAS thinks the drive is part of the array, then the volume will be flagged as degraded if it is missing.
    If the volume was already identified as degraded when you did this, then the NAS likely saw this as a two-drive failure, and therefore marked the volume as dead.
    I'm linux savvy.
    You could try manually removing the 10 TB drive from the array with mdadm.  That should restore the volume to degraded status, which would allow the 6 TB drive to be resynced.
    Sandshark has played with these commands more than I have, so hopefully he will chime in.
    • Sandshark's avatar
      Sandshark
      Sensei
      The NAS has labeled two parts of the former "data" array as data-0 and data-1 because it can't have multiple volumes named "data".  Those are also the names given to the MDADM RAID groups of a two-group volume named "data".
      I don't know if anything I know of can fix your situation, as the commands normally need to operate on the un-mounted "data" volume.  If you had come here before you removed that second drive, I could have helped.  But look at my post Reducing-RAID-size-removing-drives-WITHOUT-DATA-LOSS-is-possible and post the results of commands like I use in the beginning to verify the configuration.  You'll need at least these:
      cat  /proc/mdstat
      btrfs filesystem  show  /data
      btrfs filesystem  show  /data-0
      btrfs filesystem  show  /data-1
      mdadm --detail  /dev/md127
      mdadm --detail  /dev/md126 (if md126 shows up in the btrfs command responses)
      and the same for any other RAID volumes that show up.
      From there, I'll see if it looks like something is possible, but I don't have high hopes and whatever you try will not be something I've tried before.
      • nifter's avatar
        nifter
        Sandshark Thanks for having a look.
        admin@Wingnut:/$ cat /proc/mdstat
        Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
        md1 : active raid10 sdf2[3] sdd2[2] sdc2[1] sdb2[0]
        1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
        md126 : active raid1 sde4[1](F) sda4[0]
        1953373888 blocks super 1.2 [2/1] [U_]
        md127 : active raid5 sdc3[0] sdb3[2] sdd3[1]
        15608667136 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/3] [UUU__]
        md0 : active raid1 sdf1[5] sdc1[0] sdb1[2] sdd1[1]
        4190208 blocks super 1.2 [5/4] [UUUU_]
        unused devices: <none>
        root@Wingnut:/# btrfs filesystem show /data
        Label: '43f65d04:data' uuid: 893ff390-861c-441d-b39c-8e6c707e0e1d
        Total devices 2 FS bytes used 8.14TiB
        devid 1 size 14.54TiB used 9.80TiB path /dev/md127
        devid 2 size 1.82TiB used 1.00GiB path /dev/md126
        root@Wingnut:/# btrfs filesystem show /data-0
        ERROR: not a valid btrfs filesystem: /data-0
        root@Wingnut:/# btrfs filesystem show /data-1
        ERROR: not a valid btrfs filesystem: /data-1
        root@Wingnut:/# mdadm --detail /dev/md127
        /dev/md127:
        Version : 1.2
        Creation Time : Fri Jul 3 15:58:26 2015
        Raid Level : raid5
        Array Size : 15608667136 (14885.58 GiB 15983.28 GB)
        Used Dev Size : 3902166784 (3721.40 GiB 3995.82 GB)
        Raid Devices : 5
        Total Devices : 3
        Persistence : Superblock is persistent
        Update Time : Wed May 25 20:33:37 2022
        State : clean, FAILED
        Active Devices : 3
        Working Devices : 3
        Failed Devices : 0
        Spare Devices : 0
        Layout : left-symmetric
        Chunk Size : 64K
        Consistency Policy : unknown
        Name : 43f65d04:data-0 (local to host 43f65d04)
        UUID : e8efdcdc:ce0dd1ae:d5321061:c45a5391
        Events : 44167
        Number Major Minor RaidDevice State
        0 8 35 0 active sync /dev/sdc3
        1 8 51 1 active sync /dev/sdd3
        2 8 19 2 active sync /dev/sdb3
        - 0 0 3 removed
        - 0 0 4 removed
        root@Wingnut:/# mdadm --detail /dev/md126
        /dev/md126:
        Version : 1.2
        Creation Time : Sat May 14 16:01:02 2022
        Raid Level : raid1
        Array Size : 1953373888 (1862.88 GiB 2000.25 GB)
        Used Dev Size : 1953373888 (1862.88 GiB 2000.25 GB)
        Raid Devices : 2
        Total Devices : 2
        Update Time : Wed May 25 13:56:57 2022
        State : clean, degraded
        Active Devices : 1
        Working Devices : 1
        Failed Devices : 1
        Spare Devices : 0
        0 8 4 0 active sync
        - 0 0 1 removed
        1 8 68 - faulty
ProSupport for Business
