Laserbait
Jun 25, 2017Luminary
RN316 and 6.6.1 not honoring smart snapshot management
My shares are set to "weekly" smart snapshot management. Right now, one of the shares has 12 snapshots Looks like there are 8 weekly snapshots and 4 monthly ones. I didn't create the monthly ones, why are they there?
- vandermerweMaster
The last weekly snapshot in a month is promoted to a monthly snapshot. Monthly snapshots are retained forever, although of course you can manually delete them.
The Netgear KB omits the bit about promotion to monthly snapshots.
- bedlam1Prodigy
"The Netgear KB omits the bit about promotion to monthly snapshots"
It is shown on Page 106 of the OS 6 Software manual
Link.to OS 6 Software manual
- vandermerweMaster
Yes I'm aware it is shown elsewhere ncluding the almost identical Readydata KB.
The Readynas KB is probably the one that needs to be accurate.
- LaserbaitLuminary
I just wish it was stated in the window where you set the snapshot information, because that's what I was going by.
So, now if I want to change that behavior, and just do 8 snapshots total, I could change from smart to standard management, and select 8 snapshots total. Will the system automatically remove the older snapshots?
If you switch to custom snapshots with limited retention, the system will remove the older ones it knows about. That should happen at the next scheduled snapshot time.
FWIW, the options in custom snapshots fit me better than the "smart" settings. I set most shares for 3 months retention, and "only take snapshot with changes". Some shares have shorter retention - my share for PC image backups for instance has only two weeks retention.
- HopchenProdigy
Yes, just use custom snapshot schedule. It will suit you better I think.
