fatmonk
Feb 09, 2018Aspirant
RN316 touch pad lights itself after opening and closing the door
Hi, If I open the door (the one with the touch pad on it) to the left most (at maximum angel), and then close it, the touch pad gets lit by itself. If I open the door at a smaller angel and close...
Sandshark
Feb 11, 2018Sensei
It's designed with a proximity sensor. When you open it all the way, your hand or a nearby object is likely getting close enough to set it off.
