Sandshark
Feb 27, 2023Sensei
RN3220 CPU upgrade -- Negligible effect??
I upgraded the processor of an RN3220 from an i3-3220 3.30GHz, which is dual-core 4-thread CPU, to a Xeon E3-1225 V2 @ 3.20GHz, a quad-core 4-thread CPU as comes in an RN4220 and sysbench shows almo...
- Mar 11, 2023
OK, I'm not entirely sure what was going on. I upgraded a second one and got way better results. So I swapped the memory between the two and the first one now gave me the improved speed. Just to check, I swapped the memory back, and now they both perform like this:
Test execution summary:
total time: 2.5567s
total number of events: 10000
total time taken by event execution: 20.4385
per-request statistics:
min: 1.02ms
avg: 2.04ms
max: 28.60ms
approx. 95 percentile: 11.02msThreads fairness:
events (avg/stddev): 1250.0000/27.44
execution time (avg/stddev): 2.5548/0.00So, the memory must not have been seated well, even though dmidecode showed both banks properly. Since I swapped out the memory before the CPU, I suspect that the performance shown for the original processor is also bogus.
Laserbait
Mar 06, 2023Luminary
Are all NAS's using the same HDD's?
I always use IOMeter for benching block storage. Maybe set up up a couple of iSCSI LUNS and try it.
http://www.iometer.org/
Laserbait
Ah, wait. I see - this is a CPU perf question, not a disk IO question, sorry for misunderstanding.
Did you upgrade the memory to 8GB to match the RN4220? I have not been able to see a pic of the motherboard, but if the 3220 has only 1 4GB DIMM, and the 4220 has 2 4GB DIMMs, it could be using dual channel mode which greatly improves memory access throughput.
- SandsharkMar 06, 2023Sensei
Yes, I also upgraded the memory to 2 4GB DIMMs, as the motherboard does appear to be dual-channel (two colors of DIMM slots).
- LaserbaitMar 07, 2023Luminary
I wish Netgear had included dmidecode in the tools of the base OS. If it were, you could use the examples from here (https://askubuntu.com/questions/1330514/how-to-check-ram-channel) to make sure that it was running in dual channel.
You might be able to see the memory config from the BIOS if you still have the monitor hooked up.
