Sandshark
Feb 27, 2023Sensei
RN3220 CPU upgrade -- Negligible effect??
I upgraded the processor of an RN3220 from an i3-3220 3.30GHz, which is dual-core 4-thread CPU, to a Xeon E3-1225 V2 @ 3.20GHz, a quad-core 4-thread CPU as comes in an RN4220 and sysbench shows almo...
- Mar 11, 2023
OK, I'm not entirely sure what was going on. I upgraded a second one and got way better results. So I swapped the memory between the two and the first one now gave me the improved speed. Just to check, I swapped the memory back, and now they both perform like this:
Test execution summary:
total time: 2.5567s
total number of events: 10000
total time taken by event execution: 20.4385
per-request statistics:
min: 1.02ms
avg: 2.04ms
max: 28.60ms
approx. 95 percentile: 11.02msThreads fairness:
events (avg/stddev): 1250.0000/27.44
execution time (avg/stddev): 2.5548/0.00So, the memory must not have been seated well, even though dmidecode showed both banks properly. Since I swapped out the memory before the CPU, I suspect that the performance shown for the original processor is also bogus.
Sandshark
Mar 07, 2023Sensei
Dmidecode confirms one DIMM in channel A and one in Channel B. But for grins, I put both in Channel A and the result was basically no change (within the normal variation since the OS background tasks are also running).
Sandshark
Mar 11, 2023Sensei
total time: 2.5567s
min: 1.02ms
avg: 2.04ms
max: 28.60ms
Threads fairness:
- LaserbaitMar 15, 2023Luminary
Well, that awesome! Very strange and confusing, but hopefully it stays consistently fast.
- SandsharkMar 17, 2023Sensei
Well, turns out I messed up and used --cpu-max-prime=10000 instead of 100000 in the re-test. So I'm back where I was wondering why this CPU upgrade seemed to do no good and why this newer CPU is slower than the one in my older NAS.
For grins, I found a cheap Xeon E3-1270 (V1), which is marginally faster but has hyper-threading. It didn't work at all. But it also has no video capability. And while there is no video port on the computer, the BIOS may be looking for that.
