Sandshark
Feb 27, 2023Sensei
RN3220 CPU upgrade -- Negligible effect??
I upgraded the processor of an RN3220 from an i3-3220 3.30GHz, which is dual-core 4-thread CPU, to a Xeon E3-1225 V2 @ 3.20GHz, a quad-core 4-thread CPU as comes in an RN4220 and sysbench shows almo...
- Mar 11, 2023
OK, I'm not entirely sure what was going on. I upgraded a second one and got way better results. So I swapped the memory between the two and the first one now gave me the improved speed. Just to check, I swapped the memory back, and now they both perform like this:
Test execution summary:
total time: 2.5567s
total number of events: 10000
total time taken by event execution: 20.4385
per-request statistics:
min: 1.02ms
avg: 2.04ms
max: 28.60ms
approx. 95 percentile: 11.02msThreads fairness:
events (avg/stddev): 1250.0000/27.44
execution time (avg/stddev): 2.5548/0.00So, the memory must not have been seated well, even though dmidecode showed both banks properly. Since I swapped out the memory before the CPU, I suspect that the performance shown for the original processor is also bogus.
Laserbait
Mar 15, 2023Luminary
Well, that awesome! Very strange and confusing, but hopefully it stays consistently fast.
Sandshark
Mar 17, 2023Sensei
Well, turns out I messed up and used --cpu-max-prime=10000 instead of 100000 in the re-test. So I'm back where I was wondering why this CPU upgrade seemed to do no good and why this newer CPU is slower than the one in my older NAS.
For grins, I found a cheap Xeon E3-1270 (V1), which is marginally faster but has hyper-threading. It didn't work at all. But it also has no video capability. And while there is no video port on the computer, the BIOS may be looking for that.
