midim
Aug 09, 2018Aspirant
RN3220 Ethernet ports problems
Dear members, Any help is appreciated. We are experiencing problems with our storage RN3220. For 2 weeks now we are looking for the problem with ehternet ports on the unit. After double checking a...
midim
Aug 16, 2018Aspirant
After thought that the problem is resolved with changing ports and excluding the cabling as a problem.
We tested the server room cabling with Fluke Versiv tester. Everything is ok.
When the problem ports are disconnected and reconnected - sometimes the device decides to go with 100Mbit, sometimes on 1Gbit
I have a case number, but firstly after trying the suggested steps from support I closed the case, but the problem still exists.
Aug 17, 2018Guru - Experienced User
Can you test with a different switch? I think you've tried everything else.
