BJB
Oct 05, 2022Aspirant
RN424 Firmware update
Greetings, My RN424 is on firmware version 6.9.5 Hotfix 1. My current version alert says 6.10.8 is available. Are there any major issues with 6.10.8 I should be aware of or is there any...
- Oct 05, 2022
One user posted that they had an issue with onedrive
I haven't seen any follow up yet (or confirmation from other users). If you were to see this, then you could downgrade to 6.10.7.
BJB wrote:
is there any issue moving from my current version to the new one?
If you use an rsync backup job to back up your entire data volume, then you will need to go to the "advanced" setting page for the backup job and enable "multiple file systems". If you don't do that, the backup job will silently fail.
Oct 05, 2022Guru - Experienced User
- BJBOct 05, 2022Aspirant
Thanks to you both. I don't use Rsynch oR Onedrive so sounds like I Should be good.Thanks!
New Tablet. Newest samsung Android OS and Still This Forum Forces Auto Capitalization. So Strange. Is There A Workaround For Anyone Else That Has This?
BJB
- StephenBOct 06, 2022Guru - Experienced User
It's not the forum.
- BJBOct 06, 2022AspirantThanks. O yes, know that. But this is the only site where every word gets capitalized....not just the first letter of the first word at the beginning of a sentence. But every word. Never have that on any other site. O well, not the biggest issue 😀
