KSMBln
Nov 22, 2020Follower
RN426 Raid0
Hallo zusammen, In den Bedienungsanleitungen die ich gelesen habe wird nur über ein Reset und die Standarteinstellungen gesprochen, leider nicht, wie ich entsprechende Rais fest einstelle. So zum...
Nov 25, 2020Guru - Experienced User
Do you want to have 6 volumes (one per disk)?
Assuming you do, then you switch to FlexRAID by clicking on the XRAID control on the volume tab. If there is a green stripe on the control, then XRAID is enabled. Otherwise FlexRAID is enabled.
After that you destroy the current volume (which is done via the volume settings wheel). That wil also destroy your shares (and your data).
Then you select each disk (from the graphic in the center of the screen), and create a JBOD volume.
Once the volumes are created, you re-create the shares and restore the data - leaving adequate free space on each volume. I recommend 20% free space for each.
- Dec 25, 2018Retired_Member
- Jan 19, 2019Retired_Member
