timvels567
Mar 20, 2025Aspirant
RN428 - Lost Volume, But Data Is There (64 TB)
Hi NAS - RN428 (2019) HDD - WD 14tb x 3 and 16tb x 1 (Total 4 disks, now expanding to 2 more) Latest ReadyOS 6 X-RAID = RAID5 In office we were trying to expand the disk array and a...
Mar 20, 2025Guru - Experienced User
timvels567 wrote:
Is there any possibility of resurrecting this back to life? Or fix the volume pool without destroying the data?
There is backup but not all of 64 TB is backed up so we need this fixed without depending on backup.
Maybe. See if you can download the full log zip file from the logs page. There should be a lot more information in there.
It can be hard to analyze - if you'd like I can take a look. You'd need to upload the zip to cloud storage (dropbox, one drive, google drive, etc). Then send a private message (PM) that includes a link to the zip. Make sure the permissions are set so anyone with the link can download. Note you send a PM using the envelope icon in the upper right of the forum page.
Don't post the zip link publicly, as there is some privacy leakage if you do that.
Sandshark
Mar 21, 2025Sensei
That you cannot start SSH is odd. By "Start", I'm assuming you can't enable it in the GUI, not that you can't connect when it's already enabled. A bad data volume shouldn't affect that. Two things that can are that you are still using the default password and that something is wrong with the OS partition (like maybe it's full). I suppose that a too=full OS partition could also be at fault for the expansion not occurring properly. Interrupting a RAID sync in progress is most likely what resulted in the data volume loss, though there is some change the cause is the same as the others.
Do check, or ask StephenB to check, your logs first. But I'm wondering if you could boot (preferably in read-only mode at least at first) with just the top two drives.
- StephenBMar 21, 2025Guru - Experienced User
It shouldn't. But in fact it does. That is why I recommend enabling ssh during setup, to make sure you can use it when you need it.
- timvels567Mar 21, 2025Aspirant
Hi all,
So it looks like we have to use a recovery software and transfer the files to another nas or hdd. This might take some time to get new drives and get them out.Thanks to all for helping out!
- SandsharkMar 22, 2025Sensei
So you've been unable to download the logs? You've been unsuccessful in trying to boot with just the top two drives?
I think you misunderstood the point of StephenB's last post. He is saying that the lack of a mounted volume always results in the inability to enable SSH, so that's not pointing to an issue with the OS partition, as I suggested it might. Since there is no technical reason for that, it must just be something Netgear blocks (as they do when the password is still the default). But it doesn't stop you from doing more troubleshooting, as nothing we've suggested requires SSH.
