herbg
Dec 19, 2020Tutor
RN516 Expansion to 24TB?
I'm rapidly running out of storage space on my RN516, running OS 6.10.4. I have about 1.64TB free of a total of 18.17TB of available space. I'm running RAID 5 on 6 4TB hard drives. I use this NAS...
- Jan 01, 2021
Thanks for the valuable tips on Snapshots. I will make sure all 4 NAS's are setup this way. I've schedule in Scrubbing, Defragmentation, and Balancing to run every 4 months, after an initial run in January!
herbg
Dec 20, 2020Tutor
Yes, I'm using X-RAID with the 6 4TB drives in Raid-5.
Is there a calculator or formula that I can use to determine the most economical path to expanding the volume?
If I'm replacing 2 drives in the NAS (one at a time, as you suggest), what is the impact of using a 6 TB vs 12TB
or even 16TB drives? Trying to do some cost/benefit analysis on getting the most space.
