adinx
May 24, 2017Aspirant
RN516 "mount_block_root + 1f1" after os 6.7.3 update
Hi there, I tried updating from 6.7.2 to 6.7.3 today and it has killed my Readynas. Now I have the error mount_block_root +1f1 whenever it boots. I have tried to do the usb recovery but i...
- May 26, 2017
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
If you can't do USB Boot Recovery despite trying multiple different USB keys and following the directions you'll need to contact support.
adinx
May 25, 2017Aspirant
Sorry, Windows 8.
Tintin75
Bonjour,
Après la mise à jour du firmware, 6.7.3 j'ai un message à l'écran :
mount_block_root
+1f1
Modèle du NAS RN31400
Le serveur n'est pas visible sur le réseau local, impossible de faire quoi que ce soit.
Fichier clients sur le serveur, que dois-je faire pour annuler la mise à jour.
Merci d'avance.
