kaydaryl
Mar 16, 2018Follower
RN516 "mount_block_root + 1f1" after power surge even after USB recovery
Hi, I recently had a power surge and found my server + NAS both had rebooted. The server (HP microserver gen8) booted fine but the RN516 is reporting "mount_block_root + 1f1." Following advice read o...
- Mar 17, 2018
This should be fixed now. Please confirm by seeing if it will boot normally now.
You shouldn't run into the mount_block_root error again on this system.
Mar 17, 2018Guru - Experienced User
Try powering down and removing all disks (labeling by slot).
Then power up diskless, and see if you still get the same error. RAIDar should then detect the NAS and report a "no disks" status. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
That should help you rule out any issue with the chassis.
