tijgert
Aug 24, 2016Guide
RN516. Volume: System volume root's usage is 81%
I'm running an RN516 on OS 6.5.1 with 6x 6TB WD RED's.
Out of the blue I get a "Volume: System volume root's usage is 81%" error.
I'm not running *any* 3rd party apps and only use the unit ...
- Sep 16, 2016
Hello tijgert,
It seems you have posted the same problem twice. Please continue at https://community.netgear.com/t5/Using-your-ReadyNAS/RN516-Volume-System-volume-root-s-usage-is-81/m-p/1140518#M115751
Regards
Aug 30, 2016Guru - Experienced User
This is really hard to follow, because your cut/paste lost all the line breaks.
You do need to log in as root, not admin - otherwise there are files/folders you won't be able to look at. So try again using root as the username, and the NAS admin password for the password.
