tijgert
Aug 24, 2016Guide
RN516. Volume: System volume root's usage is 81%
I'm running an RN516 on OS 6.5.1 with 6x 6TB WD RED's.
Out of the blue I get a "Volume: System volume root's usage is 81%" error.
I'm not running *any* 3rd party apps and only use the unit ...
- Sep 16, 2016
Hello tijgert,
It seems you have posted the same problem twice. Please continue at https://community.netgear.com/t5/Using-your-ReadyNAS/RN516-Volume-System-volume-root-s-usage-is-81/m-p/1140518#M115751
Regards
tijgert
Sep 16, 2016Guide
Hello Sir,
I don't know how you're looking at my post, but it is showing normal as a listing on a grey background with all the line breaks when pulling up the page. Only when looking at your reply do I see one big jumble of symbols.
May I suggest you view it regurlarly? No one else seems to be having the problem you are.
Any help is greatly appreciated.
Cheers,
Ray
JennC
Sep 16, 2016NETGEAR Employee Retired
Hello tijgert,
Regards
