tijgert
Aug 24, 2016Guide
RN516. Volume: System volume root's usage is 81%
I'm running an RN516 on OS 6.5.1 with 6x 6TB WD RED's.
Out of the blue I get a "Volume: System volume root's usage is 81%" error.
I'm not running *any* 3rd party apps and only use the unit ...
- Sep 16, 2016
Hello tijgert,
It seems you have posted the same problem twice. Please continue at https://community.netgear.com/t5/Using-your-ReadyNAS/RN516-Volume-System-volume-root-s-usage-is-81/m-p/1140518#M115751
Regards
tijgert
Sep 16, 2016Guide
Hello,
I checked the thread and do not see a double post in my name. I do see that mdgm made a double post.
Could you clarify what you mean?
Ray
Ray
- StephenBSep 16, 2016Guru - Experienced User
tijgert wrote:
Whatever the reason, we have two threads started by you on the same topic. Jenn is suggesting that we stick with one. Let me know if I can lock this one.Whatever the reason, we have two threads started by you on the same topic. Jenn is suggesting that we stick with one. Let me know which one you want to use, and I'll lock the other one..
The two threads are this one:
https://community.netgear.com/t5/Using-your-ReadyNAS/RN516-Volume-System-volume-root-s-usage-is-81/td-p/1140605
and this older one:
