dsnpevl
Dec 21, 2014Virtuoso
RN516 with OS 6.2.1 hangs network on Fritz!box 7360
Hi Forum, I have a weird issue with RN516 with OS 6.2.1 and Fritz!box 7360 router with OS 06.20 and firmware 111.06.20. Before upgrading to OS 6.2.1, the setup with the same router worked fine. ...
nsne
I created a more general thread for this problem here: http://www.readynas.com/forum/viewtopic ... 65&t=79118
I had the exact same situation with a 314 and a DrayTek Vigor 2130Vn.
When did you update to 6.2.1? According to this thread — http://www.readynas.com/forum/viewtopic ... 65&t=79120 — there were two 6.2.1 "final" updates. Reverting back to RC3 solved the issue for me, and I'm hesitant to update to the final 6.2.1 in case this problem persists even in the "final final" 6.2.1.
EDIT: You're using IPv6? That might be a commonality. I'm using IPv6 locally too.
