arlington's avatar
arlington
RN51600 – ReadyNAS 516 6-Bay will not boot - recovery options?
My RN51600 stopped working after a power outage, with an error message on the panel stating "mount_block_root +25e" Powering it down and then powering it up again gives the same message. I removed a...
  • StephenB's avatar
    Apr 14, 2020
    arlington wrote:
    Do I have any options for reviving the chassis?
    Not sure.  It sounds like the flash is damaged.  You could try USB recovery. https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
    If the NAS is under warranty (5 years) then you could try getting a warranty replacement (RMA) via my.netgear.com.
    arlington wrote:
    Would I be able to mount the drives in a new chassis (without losing my old data of course)?
    Probably.  If the disks were damaged when the power failed, or if the array went out-of-sync due to lost (cached) writes, then you'd need data recovery (which might not be possible, depending on the circumstances).  But if the array/disks are intact, then you can move the disks to another OS 6 ReadyNAS (for instance, an RN526x, RN528x, RN626x, RN628x).
    I suggest getting a UPS to prevent this from happening in the future.  Also, you should put a backup plan in place for the NAS.
ProSupport for Business
