demoleon63
May 31, 2016Aspirant
RN51600 No longer accessible after upgrade to 6.5
Since upgrading to 6.5 I am no longer able to access my shares via my Windows 10 office desktop. My windows 10 network locations don't work any more and if I browse to the RN516 (I can see it on the...
- Jun 01, 2016
Yes, I do. I noticed that my theater PC was set on a local account so I changed my office PC to a local account too and now everything is back to normal. I can access all my shares as usual. So I guess my problem is solved for now.
Thanks,
John
AlisterFiend
I have the same issue. I log into all of my Windows machines with my Live email account. My Win10 under Parallels on my Mac works fine but a new install of Win10 and another system show the RN516 in Explorer but state Windows cannot access \\Servername\Share Cannot access it via direct IP either.
mdgm-ntgr
May 31, 2016NETGEAR Employee Retired
If you use ReadyCLOUD with this NAS, do you use that same email address for your NETGEAR account for use with ReadyCLOUD?
- AlisterFiendJun 01, 2016Aspirant
I used the same email for both. I currently have ReadyCloud disabled while I troubleshoot this issue.
- StephenBJun 01, 2016Guru - Experienced User
I believe that's the issue (and that Netgear is working on a fix).
