chopin70's avatar
chopin70
Virtuoso
Sep 27, 2019
RN524X 10G port to Multi Gig 5G port of the MS510TX switch
Hi,
I own a RN524X NAS model.
I want to buy a 10 Gb affordable switch. I am interested in the Netgear MS510TX Switch.
It has 1xRJ45 10Gb port, 1x SFP+ and 2x 5Gb ports.
I have a server with an ASUS 10 Gb LAN adapter that will connect to the switch 10 Gb port.
If I connect the RN524X to one of the 5G ports, will I get 5Gb link or the NAS will drop to 1Gb link ?
Else, is there a compatible SFP+ adapter for the MS510TX to connect an RJ45 copper cable to the 10 Gb RN524X port ?
Note: 5Gb speed is fine for me to the NAS
  • schumaku's avatar
    schumaku
    Most likely not - because if the RN524X does not come with a Multi-Gig capable 10GbE interface, it would negotiate to 1 GbE.
    Official answer: The Netgear AXM765 SFP+ Transceiver 10GBASE-T (max 30 meters)
    Inofficial answers:
    There are Netgewar AXM765 compatible SFP+ modules available in the market for a fraction of the Netgear price tag, also limited to 30 meters..
    The "smaller" Netgear switches don't check the product ID of the SFP+ modules (residing in a Flash) - you can have luck with "any" Generic (or other brand marked) Compatible 10GBASE-T SFP+ Copper RJ-45 Transceiver Modules which are available for driving 30 meters (less expensive) or up to 80 meters (more expensive). The limited reach (compared to 10GBase-T) is because of the limited power available on the SFP+ ports.
    • chopin70's avatar
      chopin70
      Virtuoso
      many thanks !
      However, are we sure the RN524X 10 Gb port doesn't support Multi Gig standard ? Is there a way to be sure about it ?
      Prices of 3x 10 Gb switches are crazy...
ProSupport for Business
