jads123's avatar
jads123
Tutor
Jul 25, 2026
RN626X: Data array missing from mdstat after OS reinstall (password recovery)
Hi all,   Hoping someone can help me safely recover my data array. Details below:   MODEL: ReadyNAS RN626X, 6 disks, RAID 5, ~18TB data (OS 6)   TIMELINE: 1. Admin password stopped working une...
  • StephenB's avatar
    Jul 25, 2026
    jads123 wrote:
    QUESTION: Is it safe to manually reassemble the missing data array via mdadm/SSH,
    There is always some risk, but often that is small.  Download the full log zip file, so you can see more details.  If you need help analyzing, then you can upload the full zip to cloud storage, and PM me link (using the envelope icon in the upper right of the forum page).  Make sure the permissions allow anyone with the link to download.
    jads123 wrote:
    md0 : active raid1 (6 disks) — 4GB, this looks like the OS partition
    md1 : active raid10 (6 disks) — ~1.5GB, created Jul 10 2026, likely a system/swap partition
    Yes.  md0 is the OS, and md1 is swap.
ProSupport for Business
