ronaldvr2132
Jan 24, 2021Apprentice
RN628X V6.10.4 Unresponsive both with usage of SMB Shares as the admin webconsole
Since a couple of days my RN628X is becoming slower and slower and had reached the point that I can't use it any longer. Everything seems to function correctly and I don't see any erorrs, but opening...
Jan 24, 2021Guru - Experienced User
FWIW, I am not seeing this on my own NAS.
Have you tried rebooting, and see if that restores performance?
- ronaldvr2132Jan 24, 2021Apprentice
Yes I did serval times. I don'have a clue what is causing the non responsiveness. It is really painfull and makes it that I can't use my NAS any longer. I have removed the scheduled maintenance jobs on my volume as they were taking an extreme long periode (more than 5 days) and during this period the performance was bad, but even then the performance was way better than it is now. Is there a maintenance task I should perform now that could help?
- StephenBJan 24, 2021Guru - Experienced User
Have you looked in system.log and kernel.log for errors?
What are you seeing in loadavg.log?
How full is the data volume?
Hi StephenB I am certainly not an expert on how to read the logs, but in the kernel.log I see these entries:
Jan 24 14:02:08 RN628X-1 kernel: md/raid:md127: read error corrected (8 sectors at 6798319872 on sdc3)
Jan 24 14:02:08 RN628X-1 kernel: md/raid:md127: read error corrected (8 sectors at 6798319880 on sdc3)
Jan 24 14:02:08 RN628X-1 kernel: md/raid:md127: read error corrected (8 sectors at 6798319888 on sdc3)
Jan 24 14:02:08 RN628X-1 kernel: md/raid:md127: read error corrected (8 sectors at 6798319896 on sdc3)
Jan 24 14:02:08 RN628X-1 kernel: md/raid:md127: read error corrected (8 sectors at 6798319904 on sdc3)
Jan 24 14:02:08 RN628X-1 kernel: md/raid:md127: read error corrected (8 sectors at 6798319912 on sdc3)
Jan 24 14:02:08 RN628X-1 kernel: md/raid:md127: read error corrected (8 sectors at 6798319920 on sdc3)
Jan 24 14:02:08 RN628X-1 kernel: md/raid:md127: read error corrected (8 sectors at 6798319928 on sdc3)
Jan 24 14:02:08 RN628X-1 kernel: md/raid:md127: read error corrected (8 sectors at 6798322560 on sdc3)
Jan 24 14:02:08 RN628X-1 kernel: md/raid:md127: read error corrected (8 sectors at 6798322568 on sdc3)I guess this is Disk 3 that has the blue light not shining blue constantly whereas the other disks do shine blue almost all the time. Could it be a disk failure that occupies the NAS heavily? I don't see any error and also the health of the disk seems to be oke.
loadavg.log -> here is an example (not sure how to read this):
01:46:37 up 27 days, 5:03, 0 users, load average: 2.22, 2.60, 2.63
The data volume has a free size of 17.76TB of the total of 36.36TB.
If it is an eminent disk failure I would expect an error message, but I can't see any. All signs are green. Is there a test I can perform or something?
