ronaldvr2132
Jan 24, 2021Apprentice
RN628X V6.10.4 Unresponsive both with usage of SMB Shares as the admin webconsole
Since a couple of days my RN628X is becoming slower and slower and had reached the point that I can't use it any longer. Everything seems to function correctly and I don't see any erorrs, but opening...
Sandshark
Jan 24, 2021Sensei
If you enable SSH and connect to the NAS via it, top can help you determine if there is a runaway process eating all the assets. But you might also get similar results if you are experiencing a lot of retries on the network. Have you tried another cable and connection on your router/switch?
ronaldvr2132
Jan 29, 2021Apprentice
I have reclaced hard disk 3 with a spare that I had, the volume was resynced and is reducndant again and now the led is the same blue as the other disks and the performance seems to be the same as before. So it seems to have something to do with the hard disk, but there has been no message whatsover that the disk has an issue. The health data did not show any error either. I would expect that an disk error would be showing up in the logs and I also would expect an alert to be send via e-mail. Has anyone an idea why I was not informed and furthermore the disk itself has still warranty, but if it will be tested I am afraid it will show up as fully functional. Any advice?
