DataPuppy
Mar 04, 2014Follower
RND104 Catastrophic Failure
I recently bought an RND104 (2 weeks ago) with the supported WD RED 2Tb NAS drives. I updated the unit to Firmware 6.1.6 and configured my system for RAID10 to provide the best protection possible. Al...
vandermerwe
Mar 04, 2014Master
Have you tested the drives with Wd lifeguard? That will sort out whether it is a drive problem.
If the drives are ok, then Netgear should give you a new chassis.
If the drives are bad, then the supplier should exchange them.
I agree it's frustrating, but I don't understand why this is not easy to sort out.
