davidtheo
Nov 12, 2011Aspirant
RND2000 and RND4000 Questions
I am thinking of buying an RND2000 or RND4000 and I would like to know if I can 1, Host web sites both ASP.net and PHP? 2, Can I upgrade the php version? 3, Can I install the Zend framework and ...
mdgm-ntgr
Nov 13, 2011NETGEAR Employee Retired
1. There are PHP community add-ons. I'm not sure about ASP.net
2. Recommended to install community add-on rather than write something yourself. Also be sure to install EnableRootSSH (http://www.readynas.com/?p=4203) first. Updates to the PHP add-ons may be made over time.
3. I don't know.
4. MySQL is already installed. If you don't use ReadyNAS Photos you can install the MYSQLON community add-on to activate it.
5. Yes, apache is used.
3. I don't know.
