davidtheo
Nov 12, 2011Aspirant
RND2000 and RND4000 Questions
I am thinking of buying an RND2000 or RND4000 and I would like to know if I can 1, Host web sites both ASP.net and PHP? 2, Can I upgrade the php version? 3, Can I install the Zend framework and ...
sphardy1
Nov 13, 2011Apprentice
Seems to me you would be better off investing in a standard Linux box (or even a Windows box given the ASP.ne requirement?)
While a ReadyNAS runs Linux, it is heavily customized, not the latest version, and you dont have full control of the installation. Neither is it designed to be a web development box. What you want to do is possible, but not the easiest solution by any means
