IBICO
Sep 09, 2012Aspirant
RND2000 V1 firmware update on usb stick?
I tried to google it several times, but can`t find anything about it. So if anyone could help?
I have a RND2000 DUO V1 HW2 where I somehow don`t get in on setup. So I must try firmware upgrade to reset password. (or is it any other way?)
The firmware on it according to RAIDar is 4.1.8. so now there is a 4.1.9 version I could upgrade to.
e-mail reset did not work.. Maybe I have forgot to setup the mailserver correctly last time?
- mdgm-ntgrNETGEAR Employee RetiredSee http://www.readynas.com/kb/faq/boot/how_do_i_reset_my_readynas_admin_password
Do an OS Re-install.
Don't upgrade to 4.1.9 as that has an ownership issue. Stay on 4.1.8 for now. - IBICOAspirant
mdgm wrote: See http://www.readynas.com/kb/faq/boot/how_do_i_reset_my_readynas_admin_password
Tried that.. It just hang there and do nothing when I answer and press. It never send me an e-mail.
Should I do a OS-Reinstall? that would only reset settings and such without reformat the disks? - mdgm-ntgrNETGEAR Employee RetiredI said to do an OS re-install (firmware re-installation) the second suggestion made in that link. Since the password recovery obviously didn't work, the firmware re-installation is the next thing to try.
Here's a link to the boot menu: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu#duo_nv_nv_x6600
