Papson
Sep 12, 2017Aspirant
RND2000 v2
Hi. I wanted to insert second hdd to nas. Raidar 6.3 cant do raid 0 or jbod, I had to use raidar 4.3.8. But after reboot second hdd lost from system. After that, I insert hdd in PC to check for corru...
- Sep 13, 2017
I find the answer by typing "netgear lock hdd" in google
Papson
Nas do erasing more then 9 hours, the lights is on, but raidar did not see the device.
Papson
Sep 13, 2017Aspirant
- PapsonSep 13, 2017Aspirant
But this solution not work - I need to boot it into tech support mode, RAIDar should give you a 5 digit codea and after then I need a password from Netgear expert or some one from netgear support.
Or maybe problem with device - its do reset aftere every reboot.
And I cant install ssh - its need reboot :(
- StephenBSep 13, 2017Guru - Experienced User
Right. Do you know how to use Linux shell commands?
StephenB wrote:
Papson wrote:But this solution not work - I need to boot it into tech support mode, RAIDar should give you a 5 digit codea and after then I need a password from Netgear expert or some one from netgear support.
Yes.
