clembo
Oct 25, 2021Follower
RND2000v2 need reset?
Help please reset required on my old RND2000v2. Was originally on a windows network but now moved to a new Linux network. Can't remember password/login etc getting all lights flashing intermitent wit...
Oct 25, 2021Guru - Experienced User
clembo wrote:
Help please reset required on my old RND2000v2. Was originally on a windows network but now moved to a new Linux network. Can't remember password/login etc getting all lights flashing intermitent with or without drive(s) in place. Getting return on ping address OK. I need to reset box but pin implement into reset button in back doesn't seem to be working. Instructions please?
First let's confirm the plaform.
The original Duo (called a v1 here)
- says ReadyNAS Duo on the front panel
- has other labels that might say RND2000v2
- runs 4.1.x firmware
The Duo v2
- says ReadyNAS Duo v2 on the front panel
- runs 5.3.x firmware
Based on this info, which platform do you have?
