helnas
Nov 01, 2016Tutor
rnd2000v2 (readynas duo v2) upgrade to os 6
Hello, I’ve an ReadyNAS duo v2 and I want to upgrade to os 6 or higher. I’ve read that is possible, but I could’t find the correct steps as well the firmware? I just use the ReadyNAS to stor...
- Nov 02, 2016
helnas wrote:
About going to OS 6, if i increase the RAM to 512MB, it will solve the slow performance?
You can't, since the RAM is soldered into the system board
helnas wrote:
I'm managing folders with photos and videos insiide, I'm not willing to define file permitions, but folders instead.
I've folder each year, and each months of the year inside.
For instance on Year 2016, I want to have the November month with read/write/delete but the others months no, and everithing inside the same year of 2016!
And to get the more complex:
- User 1: read/write/delete => to November folder
- User 2: read => to all folders
- User 2: read/write/delete => to all folders
One option is to use two shares - "current" which holds a folder for the current month, and "archive" which holds the folders for all previous months (use whatever names you want of course). Set up the share-level permissions to give user 1 full access to current, and read-only access to archive. Set up user-2 to have full access to both shares.
Then you add in a frontview backup job that copies current to archive. Run that manually at the beginning of each month. Then delete "november" from "current" and make a new "December" folder there.
Nov 01, 2016Guru - Experienced User
helnas wrote:
With this setup, administrator can write or delete any folder, but myself and my wife just can read/write/delete some of them.
I don't believe that is possible on windows because it's managed by ReadyNAS!
There are two different sets of permissions. One is "network permissions" and the other is "file permisisons". Network permissions apply to the entire share, and control which users have access to that share. File permissions apply to specific files. To access a file you need to have both sets of permissions.
You can make adjustments to file permissions in network shares from windows.. You do need appropriate permissions (both network and file) to the share and the subfolder the file is in.
The topic is confusing, and lots of users have trouble with it. There is guide for OS-6 here: http://kb.netgear.com/app/answers/detail/a_id/29838 Unfortunately there is no similar guide for the v2 products.
My guess is that you'd prefer it if both you and your wife could read/write/delete everything. Is that correct?
mdgm-ntgr
Nov 01, 2016NETGEAR Employee Retired
256MB RAM is barely enough to run the OS let alone deal with actually using the box to store data on it. OS6 on the Duo v2 would run into the OOM condition very easily.
