Nigewood
Dec 26, 2019Aspirant
RND2000V2 stuck on firmwaren RAIDiator 4.1.16 [1.00a043] and wont upgrade
Currently on 4.1.16, wont automatically update or fails is I go to 5.x.x
- Dec 31, 2019
Nigewood wrote:
Hostname: Mini-Nas Model: ReadyNAS Duo Serial: 24M41A7401410 Firmware: RAIDiator 4.1.16 [1.00a043] Memory: 256 MB [2.5-3-3-7] Will not Upgrade to the latest firmware!!!
Not true. You are running the latest firmware already.
Your confusion is that you mistakenly think you have a v2 (arm-based) NAS. In fact you have a v1 (sparc-based NAS). The labeling is confusing, and there are lots of people who have made your mistake.
A v1 NAS
- runs 4.1.x firmware and cannot run 5.3.x
- has Duo on the front panel
- Might have labels that say v2 or even v3 on the side or back.
A v2 NAS
- runs 5.3.x firmware and cannot run 4.1.x
- has Duo v2 on the front panel
FWIW, both NAS were discontinued long ago - your Duo was discontinued in 2011. A new NAS would be 4-5x faster, and would have more features. The current entry level ReadyNAS is the RN212.
Nigewood
Dec 30, 2019Aspirant
| Hostname: | Mini-Nas |
| Model: | ReadyNAS Duo |
| Serial: | 24M41A7401410 |
| Firmware: | RAIDiator 4.1.16 [1.00a043] |
| Memory: | 256 MB [2.5-3-3-7] |
Dec 31, 2019Guru - Experienced User
A v1 NAS
A v2 NAS
