geek01
Apr 18, 2015Aspirant
RND2110 expansion
I am new and logging in for the 1st time. I have a NETGEAR ReadyNASRND2110 and I want to put 2 4TB drives in it. Is there any firmware update that will allow to to see all 4 TB instead of seeing it a...
Apr 19, 2015Guru - Experienced User
Ok. Then the largest disks it can handle are 2 TB. You can set it up as flexraid to get 4 TB total space with two disks.
There are two ways to do that- one is "jbod" where you have a C volume and a D volume that are independent. The second way is to use a single RAID-0 volume that spans both disks.
Jbod is safer - if a disk fails with jbod, you only lose what was stored on that disk. With the single RAID-0 volume you lose everything.
Details on installing flexraid are here: http://www.downloads.netgear.com/files/ ... 6Dec11.pdf
You will need to do a factory reset (losing your config and all your data).
