kwiat87268
Jul 21, 2017Aspirant
RND2110 V2 - Software for Mac and PC DashBoard to change setting etc
Hello all, For the life of me, I can find my start up disc for my ready NAS rnd2110 ready nas duo v2. i want the software for the dashboard so I can change settings, add user names, etc. If it ...
- Jul 27, 2017
The default password on the v1 is also different - it's netgear1
So try the web ui again with that password.
Jul 21, 2017Guru - Experienced User
There is no dashboard software - it is a web application on the NAS that you access through your browser. https://nas-ip-address/admin (using the real IP address of the NAS of course).
- kwiat87268Jul 21, 2017Aspirant
This doesn't allow you to create new secured users to have their own access to file. Also I remember a dashboard to be somewhere where you can update firmware as well.
Through the way you mention, I can access what is exsiting but I can't create new setting...i.e. when you take it out of the box and installed the disk on CPU, etc.
- StephenBJul 21, 2017Guru - Experienced User
This is the admin interface for your ReadyNAS. If it isn't working there is something wrong. You can add user accounts, create/modifiy shares, update firmware etc.
The software manual for the v2 NAS is here: http://www.downloads.netgear.com/files/GDC/READYNAS%20ARM-PLATFORM%20(DUO%20V2,%20NV+%20V2)/RAIDiator%205.3%20SW%20Manual_5Sep12.pdf
You can also do some things with RAIDar. But firmware update isn't one of them. https://kb.netgear.com/20684/ReadyNAS-Downloads
- kwiat87268Jul 23, 2017Aspirant
So I realize now that using /Admin after the IP address is what I was doing wrong. However the username and password is different than the account I set up within. I set up the password recovery and it says it would send me an email resetting my password I can't rememeber. I don't get the email. So I was reading that i could reset the unit but watch that I don't delete any data.
Can someone give me some isight on either the password retrieval with the email that isn't working for me or resetting the unit WITHOUT deleting the data.
Thanks
