kwiat87268
Jul 21, 2017Aspirant
RND2110 V2 - Software for Mac and PC DashBoard to change setting etc
Hello all, For the life of me, I can find my start up disc for my ready NAS rnd2110 ready nas duo v2. i want the software for the dashboard so I can change settings, add user names, etc. If it ...
- Jul 27, 2017
The default password on the v1 is also different - it's netgear1
So try the web ui again with that password.
Jul 25, 2017Guru - Experienced User
Are you certain that you have a v2? A v2 will say "v2" on the front cover, and the part number will end with -200.
kwiat87268
Jul 26, 2017Aspirant
I replied with a pic of the bottom of the unit... Yes it is a Duo V2
- StephenBJul 26, 2017Guru - Experienced User
Actually it's a v1 (Sparc based unit) that runs 4.1.x firmware. A v2 (arm based unit) runs 5.3.x firmware.
The labels are confusing, which is why I specified looking at the front panel and for the -200 in the part number.
Anyway, the correct procedure for the OS reinstall is on page 15-16 here: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
Unfortunately the mistake means you started to execute the factory reset procedure - which is destructive. So you might have lost your data.
- kwiat87268Jul 27, 2017Aspirant
I cannot beleive it is not a Version 2... That is so ridiculous.. You are right of course. It says V2 for God's sake.
So i have some good news and some bad news.. The good news outweighs the bad news. Because the lights didn't all illuminate after I held the paperclip for 5 minutes... I pulled the plug on the unit each time I tried. Not a preferred way to shut down but I guess it prevented data from being erased. Bad news, still in the same situation. From the directions, I did the following...tried it twice.
First time:
1) Shutdown
2) Held the reset button as I powered back up
3) 5 seconds later the drive lights flashed
4) Released the reset button.
Second time:
1). Shutdown
2). Unplugged system for about 20 seconds.
3). Held the reset button
4). Plugged in system while still holding the reset button
5). Powered up still holding the reset button
6). Waited for 5 secs when the drive lights flashed
7). released the reset button.
Still cannnot get into admin settings using username: admin password: password
Also I guess I was expecting other things to go to default such as my user name and passwords to get into the usernae accounts. The set mapping for the IP address, etc. Nothing changed.
Any Ideas?
- StephenBJul 27, 2017Guru - Experienced User
- kwiat87268Jul 28, 2017Aspirant
Thank you for your help. A long road to final success. Thanks again.
Netear should be shot for saying that this is a v2 when it isn't really.... lol
- kwiat87268Jul 28, 2017AspirantSo I said in my previous message, thanks again. I read various ways to do this. Knowing my unit as you do, what is the easiest best way to update the firmware? Assume I don't know some of the steps that you would find easy.
Thanks - StephenBJul 28, 2017Guru - Experienced User
On the v1/v2 thing - your system was built before the "real" v2 products were launched. What your label means is that you have hardware revision 2 of a Duo. Netgear's mistake was branding the OS 5 NAS as v2 - they should have chosen a different product name. We've been dealing with that mistake here ever since (and I'm sure it's a pain for Netgear support also).
kwiat87268 wrote:
what is the easiest best way to update the firmware?What firmware are you running now? The label said it was shipped with 4.1.6, but I am thinking it might have been updated after that.
Actually Raidair says it is 4.1.6
Ok. So that is 8 year-old firmware. I suggest backing up the data (just in case) and then
- navigate to system->update
- click on "check for update". It should find 4.1.16
- follow the prompts to install (and restart).
