Mych
Nov 26, 2015Aspirant
RND2110v2 or not....
I have a ReadyNAS Duo RND2110v2 acording to the label at least. It has 2 x 1Tb drives as a mirrored pair. I recieved an email saying.... Dear ReadyNAS® Customer, We want to thank you for be...
Nov 26, 2015Guru - Experienced User
That email shouldn't have been sent to you. It was targetted at ultra/pro owners, but somehow was sent more broadly.
Your NAS can't run 4.2.x firmware. 4.1.14 is the current production firmware for your NAS. You'll find 4.1.15 beta firmware in the forum (which has some additional security updates).
You duo v1 can handle disks up to 2 TB, but no larger. I recommend WD20EFRX if you want to expand storage.
Mych
Nov 30, 2015Aspirant
Thanks... After posting this I did get another email that apologied for the confusion. You were right I should not have been sent the email. So you are saying that although the label says v2, I only have a v1 RND2110? Seems like a great way to confuse customer.
- DaneANov 30, 2015NETGEAR Employee Retired
Hi Mych,
In addition to StephenB's response to you, kindly access this article below for further information as reference:
http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
DaneA
NETGEAR Community Team
- mdgm-ntgrNov 30, 2015NETGEAR Employee Retired
It is a v1 hardware revision 2 as described in the article DaneA linked to.
